Is there a way to set default values for each color(layer)?
Welcome @roybrewer1943.
Read the following doc please:
Hi @roybrewer1943
You can set a different default for each color layer using Make Default in the Cut Settings Editor. Those defaults are saved separately for each device profile (as @parsec says).
If you want to save a wider range of settings for different materials/processes rather than tying them to layer colors, the Material Library is also a good option.
