The blue diode laser has a rectangular shape. Therefore, it cuts in one direction (e.g. X) better than the other direction (e.g. Y). I would like LightBurn to generate G-Code where the speed movement on the Y-axis is slower than the X-axis so that the laser has more time to burn the material while traveling on the Y-axis.
I’ve got a similar problem, but the other way: the shape is .1mm in the X, and .3mm in the Y, making it cut narrower and faster with vertical movements.
