onisuk
(Onis)
June 2, 2025, 11:27am
1
After my laser print, the head returns to my “user-defined finish position” but then it returns to home… and I can’t figure out why.
The end of the Gcode looks like this
G1 X-0.17S650
G1 X-0.075S0
G90
M9
G1 S0
M5
G90
; return to user-defined finish pos
G0 X80 Y280
M2
So I take it, its not the code doing it??
misken
(Melvin)
June 2, 2025, 1:28pm
2
Did you enable this:
Or do you call this the “user defined finish position”? Those are two different things.
onisuk
(Onis)
June 2, 2025, 1:32pm
3
yes, when enabled, it adds that code to the end of the G-code.
The laser head goes there after the job, but then instantly returns to the origin!
misken
(Melvin)
June 2, 2025, 3:11pm
4
If it’s nowhere in the sent gcode, it’s the firmware that is doing this. Maybe try LaserGRBL and check if the behavior is the same.
