How to tell if your CO₂ tube is actually dying (before you buy a new one)
Hey all,
We make CO₂ laser tubes in our workshop, and a question we see all the time is “My machine lost power — is the tube dead?” Usually it’s not. Dirty optics, bad cooling, misaligned beam path, or a weak power supply all look identical on the machine. So here’s the short version of how we test tubes in-house.
Signs that really are the tube:
  • Real power drop — used to cut 3mm acrylic / wood easily, now barely marks it; engraving depth uneven
  • Glow is pale pink or whitish instead of steady bright pink (gas aging)
  • Internal arcing / sparks inside the glass — stop immediately, it damages the PSU
  • Cracks, foggy glass, or water weeping at the ends
Quick test:
  1. Unplug, wait 10 min, inspect glass and wiring cold
  2. Cool the tube ~10 min, then cut 3mm acrylic at your normal settings. Won’t go through? Slow down and retry
  3. Fire one pulse onto cardboard at the nozzle — healthy spot is a round, solid dot. Hollow / scattered / lopsided = degraded
  4. Watch the glow while firing — flickering or color shift = unstable
Check these first (most “bad tubes” are actually these):
  • Dirty mirror or focus lens
  • Misaligned beam path
  • Weak / warm cooling water
  • Marginal power supply
  • Wrong speed/power in LightBurn for the material
Safety: PSU carries lethal high voltage — unplug and wait for caps to discharge before opening. Wear goggles. Stop on sparks, smoke, or leaks.
If you’ve got a specific symptom, drop it below and I’ll help you reason through it — happy to tell you honestly when it isn’t the tube.
I agree with most of what you write, but shouldn’t this pulse test take place at the front of the tube, on M1, in order to assess the beam distribution?
Not all co2 laser will emit a proper TEM00 resonance at low values. One of my tubes, will lase at about 10ma, but it a doughnut in shape. Not a proper tem00 operation. If I increase it to 12% or above it moves back in TEM00 mode. I’ve herd of larger tubes, taking a higher, low value to reach TEM00 from TEM01.
RF lasers don’t see this much as most co2 are designed to resonate at full power. An RF machine will turn off and on like a diode laser. Run an RF machine at 50% power, it’s on 100% for half the time and off the other half. Same with a diode.
Many of the Chinese places advise them to test at higher power levels because of this.
You can be suspicious, but it’s no guarantee it failing.
:grinning_cat:
