Newbie here…TIA for your patience. I was using Inkscape/K40 Whisperer and switched to Lightburn. When I import my previous designs that are set to vector & raster engrave, they only import as vector. Is there a way to change that? Do I need to copy and have one layer that is line and an identical layer that is fill?
You can use sublayers.
Double click the layer in the Cuts/layers window and add a second layer, one set to fil and the other to line, the same shape.
Looks like you’re looking for sublayers.
Exactly what I needed. Thank you!
