How would I make this evenly distributed holes?
I’ve confused myself but I want to make a number of holes evenly distributed around the inside edge of a defined shape.
How would I do this???
Does the process change if the shape changed to say a heart.
For example51LGCwy64DL.AC_SS350
Couple of notes regarding Copy on Path:
  • The UoM is statically metric (not respective of the Units / Grids setting Inches)
  • The path will not be followed if the replicated object is not initially placed on the path’s starting point:
When placing the circle on the target path but not on the starting point
Alternatively, when placing the circle on the target path’s starting point:
@beamer3.6, keep in mind to achieve the desired outcome illustrated in your initial post, utilize the offset tool first to generate the path to follow:
Then select that path to follow and click Set Shape Start Point (so you can locate where to place the circle):
Thank you guys. So much to this software :grin:
