I am having big ghosting issues with my Ortur laser master 2. Being new to this, the results were surprisingly good for like the first 8 prints but then at print number 6 I am sudenly experiencing these problems and they get worse every time so far…
I have checked the belt. Not too tight and certainly not too loosen. Also, the rollers seem fine and the machine has good balance while engraving. I have attached an image that has been engra
Not sure when the ghosting appears, just facing with this end result, I´ll have to check and pause the program in the middle of the print to tell you. I´ll to this today.
Try ‘fill shapes individually’, instead of ‘fill all shapes at once’
Try just ‘fill’, rather than ‘line and fill’ and see if it makes a difference. It may be that the ‘line after fill’ is the source of your ghosting.
Changing from ‘fill shapes at once’ changed the run time from 3:29 to 1:54
I would also look at increasing the power and speed - if you turn the power up from 21,7% to 50%, you should be able to double the speed.
