I am a new user and want to add a layer. I am doing a cribboard and want to put 2 skunks in side by side. Cant figure out how to do it! I thought it would be as simple as placing the graphic on my screen and then open it again and moving it beside the other, but that wont work. please help!
When using an IMAGE, they will overlay the image below. You can get better results if trace and image to turn it into an OBJECT. You can maneuver and manipulate objects to achieve (what I presume) is your goal.
Right click on the image, select TRACE, adjust the sliders to get the results that you want.
Adding to what @JimNM mentioned, you can use trace multiple times to extract difficult areas.
Thank you, will give it a try.
