It’s a solo, spare-time project, built with help from AI. The project is open source, and the code is on GitHub.
TopoStack is free for personal and commercial use. If it becomes a useful part of your business, please consider a donation to help support continued development. Donations are entirely optional.
Bathymetry (underwater terrain) is still a work in progress, since freely available data can be hard to find. I also plan to add more map layers, including aviation sectional charts and additional boundary overlays.
I’d love to hear what would make TopoStack more useful in your workflow, and see what you make!
Nice work! I’ve moved this post over to the Community Solutions subcategory.
I used to make the Bathymetry maps for Pangea Maps back in the day, and at least when I was doing it they had a handful of artists referring to charts and drawing the depth lines manually.
As a reminder, we allow discussion of entirely free tools here on the LightBurn forum - we do not allow self promotion/‘please test my new tool’ topics on the forum when there is a paid component (ex. to export to .svg, you have to buy a license). Bait and switching in this regard is also not allowed, and will be met with heavy moderation.
Thanks! I appreciate that insight! It does seem like that data just isn’t there for the vast majority of lakes. I have a background in GIS work for earthworks but we never dealt with bodies of water so that’s new territory for me. Maybe there’s an opportunity to create a conversion pipeline for existing chart data, interesting idea.
Bait and switch will not be an issue here. The whole reason I started writing this was because I felt the existing free solutions were insufficient and the paid versions were overcharging for a pretty small feature set. This software was built with the intention of being free and open source. Donations are now, and will always be, entirely optional and non-UI blocking.
Where it got 6 km of vertical relief I have no idea, but the Hudson just ain’t that deep.
AFAICT all but the top three-ish layers are blank. The Hudson River is at sea level and the fjord walls aren’t all that tall. Maybe the GIS data includes a pinhole to a reference depth?
Chrome is currently burning the CPU, so whatever it’s doing in there presents a continuous high-intensity workload.
It flat-out doesn’t work in Firefox, which is likely due to all the armor required for normal browsing.
Interesting, that’s a new one. Give me a bit to debug and I’ll get back to you.
We do run processing client-side for most of the heavy number crunching, but you shouldn’t be seeing continuous high CPU usage, just a few blips here and there as things are generated/added/removed. This is likely a render loop triggered by the overflow you are seeing in the output, I’ll debug that as well.
Your guess was right on, the elevation data contains a spike near West Point (some -7,735 m pixels beside the terrain near sea level). I’ve added a filter for those spikes system-wide, stopped the 3D preview from re-rendering while idle (even if wedged with strange data haha), and improved compatibility with Firefox’s new privacy settings.
This should be fixed, please refresh and regenerate the terrain at your convenience. Let me know if the issue persists!
Thanks! It looks like there is something to go on here. Maybe with a larger combination of sources like NOAA (and the current sources of HydroLAKES and GLOBathy) along with a DEM generator from flat charts we can get to a pretty reasonable coverage of larger lakes.
Right now, when it fails to find depth data it defaults to a somewhat generic shape based on distance to shore. I’m planning on improving that so it predicts the lake shape better based on surrounding terrain. That system will hopefully be used to fill in the data for small bodies of water that are unlikely to have depth data anytime soon.
Well, the pinholes are gone and it gets along with Firefox, so I can try more things.
The map selection (if that’s what it is) doesn’t respect the cut size / aspect ratio, so it’s difficult to decide what’s going to be in or out of bounds:
Thanks for sticking with me, I appreciate your testing and patience.
The pan zoom issue in the cut layers was implemented in the Flat mode, but I forgot to carry it back over to the Layered mode of the SVG renderer. Fixed now.
The map selection issue I simply overlooked since I was often testing by entering a location and not changing the default shape (good example of why a single person testing something often leaves gaps). My mistake, fixed as well!
I noticed your screen is quite narrow, but not yet hitting the mobile breakpoint (portrait tablet?), that is also improved in the latest version so everything is less squished at that aspect ratio.
The Firefox window covers a little more than half of a 2560×1440 landscape monitor, with its vertical tabs along the left edge soaking up some space. The result is generally OK for browsing; the adjacent 1440×2560 portrait monitor handles code wrangling / CLI text.
A paltry three-layer map with no added features came out OK:
Alright I’ve considerably improved how it generates lake depths and the data available. It uses published surveys from 11 sources and when data is missing, it models the lake floor using shoreline shape, surrounding terrain slopes, and available depth estimates. Predicted depths throw a warning indicating they’re an approximation for the model, not measured underwater terrain.
Lake depths can either be manual (following your layer and exaggeration settings) or scaled to fit the available layer depth so the bottom doesn’t get clipped on deeper lakes.
I have not yet attempted a DEM generator from flat charts, that will be a future effort.
Lake testing exposed some low-quality elevation data (as seen in the above example for Alexander Lake). I was focused on the lake modeling and didn’t notice the terrain until after my post. A fix for that is in the works using the same multi-source handler that was built for the depth data.
As it’s not possible for me to check every location at every zoom level, I’ll also be adding a feedback system so when low resolution data is found it can be reported and I will be notified to search for a higher quality data source. Typically higher resolution data exists, but is often buried in a local government website that I’ll have to explore manually.
(Old one still works too, you will just be redirected)
I just added support for splitting large maps into smaller pieces so they can be cut on smaller machines that don’t have a work area large enough for a full layer.
You can now export paper painting templates so water areas can be safely painted on each layer without fear of painting into the parts of that layer that will be visible terrain. In the future I intend to use this for other area features like BLM land, National Parks, etc.
Thanks! There are more features and improvements on the way today as well (GPX/KML/GeoJSON import support and a custom title/plaque area being the big ones).
Also working on a better changelog solution this week so it’s easier to follow along with progress.
Great work. Amazing. My dad worked for USGS as a cartographer doing survey work and his data was used back in the day for making topographic maps. After growing up as a ‘survey brat’ (we moved around a lot from project to project) I have always had an interest and appreciation of topo maps. Thanks for sharing this resource. It is always good to have more capabilities in the “toolbox”. I know this digresses from the original thread topic and my apologies, but I need some help with a mapping project where I want to engrave a world map onto a cube where the projection has the poles on opposite vertices rather than centered on opposite faces. I tried working with a free app called Qgis. It has a lot of potential but also a fairly steep learning curve to use and I’m not even sure it has the capability to map what I want even if I was an advanced user. My goal is to make a square cube globe. I have seen things like this for sale on Etsy but can’t find any images or vector files for the 6 faces of the cube. Any help or advice would be greatly appreciated.
I’ve spent a LOT of time in QGIS and wholeheartedly agree that it is equal parts amazing and overwhelming.
I didn’t anticipate a uv mapping or object wrapping feature for the “Flat” mode of TopoStack, but I don’t see why I couldn’t do a basic mapping and unwrapping feature for that part of the software. Give me a few weeks and I’ll see if I can implement something. Sounds like a fun challenge, might open up some interesting creative options for people to use.
A number of new features are available today and a fair amount of polish, including the new changelog which will do some of the announcement work for me:
I think the new assembly guides will make the process of going from raw files to finished project a lot less complicated.
