Hello, I’m installing an AC1 camera, but when I try to capture the video using the test, the “Capture” button isn’t grayed out, so I can’t continue the camera installation. Can you help me? Thank you.
Assuming your profile information is up to date, does the installed camera work with the Windows “camera” application?
I’m having the same problem. The camera instals OK and everything works OK up until trying to capture the images needed for calibration. The “capture” button is greyed out for some reason and I can’t continue. Hope someone can help.
Having read a number of posts about issues with the latest Lightburn upgrade, I went back and installed version 2.0.05. The camera installation and calibration worked flawlessly. so it seems like the latest Lightburn version has an issue. May be worth a try for you too.
