RalphU is right, you can only do it this way. But you decide for yourself whether your object should consist of 2 areas or an area and a line. After all, your line is not connected to the rest of your form.
OK,I obviously do not quite understand exactly what a shape consists of.
Even if I put in a node to connect the line to. It still won’t do it.
I just expected it to work, because it always has in Vectric Aspire.
Ah well, more study needed.
Thanks for your replies.
Maybe we could understand you a little better if we knew when and how you need to “combine” multiple objects. Try to come up with another example or explain what is not as you want in my 2 examples. It is always interesting to “see” the tasks from another side, so there is gain for both of us
