I have bought the neje max plus 2 i have been recommend to use Lightburn in this grbl but i come across with a code problem
Starting stream
Layer C00
fx��fx
fx��fx
fx��fx
fx��fx
fx��fx
fx��fx
fx��fx
fx��fx
So i have been looking around the forum and i read that someone say that i need to change $110 and $110values but when i when to the console and Type $$ and press enter the Grbl setting doesn’t come up.
After i when to the device setting and its saying no controller communication, what i found weird because i just run a file in the machine
Can someone give a hand here? i do not understand what’s going on…
When you first connect to the NEJE, what does it say in the console? The weird characters look like interference in the communication line, but could also be from the NEJE not using real GRBL firmware. Many of the NEJE devices I’ve seen don’t use real GRBL, or use a strange customized version that they wrote, removing many of the features, but leaving just enough to make it work (poorly) with other software.
