Hi, kindly since I went to version 9.11 that gives me this error what should I do to solve all this ??? Thanks
Delete duplicate shapes before you run your job, or turn off ‘Remove Overlaps’ in the cut planner.
This crash is because the shape output code isn’t expecting completely empty shapes, and the Remove Overlaps can cause it. This is fixed for the next release, and I might try to push the next one out relatively soon to address this.
Hi, When will the new release be published? With this problem that LightBurn crashes, work is becoming a problem due to waste of time and material. Thanks for the excellent work.
I think it’s stable enough to do soon.
