I have a dual pro 14w laser run on a xcarve machine. Software = Lightburn. I get som unshare letters with som blury areas between the letters. Please advice how to get rid of this problem.
A photo would be great… worth 1K words…
Please find
Off hand I’d say you are using too much power or too low of a speed…
This can be caused by too small of a line interval.
I’ll add that if you are using high flow air assist you may be blowing smoke onto the surface. Disable or reduce air to a trickle.
You may also find that a pre-treatment with a clear sander-sealer may prevent smoke marks. I believe @ferg recommends the Minwax product.
