I have a weird issue. (Setup 3018 Pro with the 5.5W diode laser installed) I do not believe it is hardware related as lasergrbl works as expected.
My issue is when using LightBurn, when I start a job the z axis seems to raise up about a quarter inch, it then runs the job, when it finishes it returns home then the z axis goes back to the starting position? It must be a setting. Any thoughts?
Do you have ‘enable z axis’ on in Device settings ? if so try turning it off if you don’t want z axis control
You may want to have a read of the various z axis controls contained in the Docs under Device Settings
