I was relocating my Shapeoko machine and my 7watt JTech laser attachment so I had to disconnect everything. When I connected it back I connected the cables wrong I connected the two similar cables in the wrong place on my laser board the black where the white one goes and the black one where the white one goes. After I did that and turned my laser on my shapeoko when besserk so I had to shut it off when I turned it back on and fixed my cables I got a message on both the carbide motion 3D app and the LightBurn software app that Homing Cycle not enable via settings and no matter what I do now I can’t get that error out I don’t know if I fried my shapeoko board can someone please help.
Did you check that homing was enabled?
Go into Carbide Motion in settings activate MDI Then enter $32=1 That fixed it for me when i had this problem. Howerver my wires were right but its worth a try.
How can I enable? Please and thank you
So, what have you done to try and correct?
Can you go into your console and type $$ then enter and copy paste here?
I input the
I input the reset code and the $32=1 and now it wants to home but for some reason my z and y AsÃx are going the opposite way
I would try File > Preferences > load pref. back up and try one before this problem started.
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=255
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
Maybe your in luck and just reset the GRBL settings.
Check if you have a copy somewhere of what you changed.
How can I reset these settings
In LightBurn Console window type $RST=* press enter and wait a little then compare values.
I did this and nothing. How do I know I fried my board ?
I don’t think the board is bad, I think your settings are messed up.
Did you load a pref. back up?
Another thing to try is check the set screws on your on your motor couplers making sure there all tight.
