Hello LightBurn forums! thank you for this excellent resource.
I have an ostrich eggbot with a diode laser attached. It has been a challenge for me to get images clearly printed on oval shaped objects. The camera feature looks promising. The “bed” is roughly 203mm X 228.6mm. The top of the enclosure is 177.8 mm above the bed. That is where I am hoping to mount the camera. Can you please recommend an appropriate camera, not sure if I should go with a 60° or a 90° lens. I am using a Mac OS. thx
Suggest you use the Camera Selection tool found in LightBurn help menu. You can enter the work area size and the tool will help you identify the camera and minimum height required to support your solution.
