I need help. im trying to burn cut out a paw print with the name attached to the paw print one with out it burninh to thing and 2 two where i can the name not to brake evertime i try to take the cut out of it. what can i do so i dot keep wasting wood. i have tryed 4 times know and the name keeps break.
It sounds like the issue might be with the design setup rather than the machine itself. To get a clearer idea, could you share a few things with us?
- A screenshot of your design in LightBurn (no phone pics please) → https://www.take-a-screenshot.org/
- The LightBurn project file itself (.lbrn2) if possible
- A photo of the finished cut showing where the name is breaking
That will help us see whether the problem is with the shapes, the text, or the cut settings.
In general, when you want text to remain connected to a cutout shape like your paw print, you should try using a stencil font like this one
Or you can try SHX single line fonts.
If you can share the design, we can point out exactly where to add those connections or how a stencil or single line (SHX) font might help!
Save your Amazon boxes and do your setups (test runs) on that. When you get what you want, then adjust the power to adjust for the expensive material.
