I need some help!
when I try and frame my item. its no longer smooth it jumps about, my calibration is almost perfect at 0.21 ive done it again tonight to be sure ! image shows up in the bed and I can see everything nice and clear, go to frame and it jumps about rather than being smooth
im having nothing but issues
you can just slow the speed down in the move window
speed
Not sure what you mean here. You have no problem when doing the job?
Which framing button are you using? The Square frame or the “O” Frame? They behave differently as described in this section in the docs: From your description, it sounds like you might be using the O Frame button, but just a guess.
