Alright, so I want to cut letter but have them be solid. You know how when you use the cut future it maintains solid power right? Well I want to do that but don’t want it to be an outline.
I want it to have a solid letter.
The reason why is because I am engraving bricks and in order for it to work I need that constant flow of power.
I want it to be a fill but running to have the consistent power of a cut. Not with the laser pulsing but continuously running as if I were doing a cut. The reason being, I need the brick to heat up enough to turn to glass and the pulsing while in fill mode just doesnt cut it. But the Cut constant pulsing power does
If you are wanting to vector engrave the lettering rather than a traditional Fill / Raster engrave, then you could create concentric inner offsets at a specific spacing that works well for your application / material.
Useful tip: after the first offset is applied, you can repeat the same offset subsequently by holding CTRL while clicking the offset tool.
