I updated to 2.2 version. Worst mistake I made
I updated to version 2.2. My laser is really jazzed up. I can’t even cut through material. I have SF-A9. It was a workhorse. I was able to cut 3 mm with fewer than 4 passes at 1000 speed. Now it won’t even cut. I went back to version 2.0.05. Still the same thing. I cleaned the lens as well. Can anyone point me in the right direction?
Is this turned on in device settings? If so try turning it off, and check that your speed settings are set right.
Thanks for the quick reply. I had to go back to the earlier version 2.0.05. Something isn’t correct. It’s still struggling. Any other help would be appreciated, for sure.
Here are some other settings.
One more. Once again thanks
From the software side, the most important thing we can check on are your cut settings. Especially that “1000 speed” - is that in mm/minute, mm/second, or something else?
Please share a screenshot of the full Cut Settings Editor for an example layer you’re having trouble with.
I would also strongly recommend rolling back to any more previous versions — if the problem persisted through the rollback from 2.2 to 2.0.05, that is already a strong indication that version 2.2 isn’t the problem at all.
It’s minutes. Thanks for chiming in.
I did roll back to 2.0.05. It appears it’s working now. That new update really did a number on me. Many thanks to you all
I have the SF-A9 40w/20w machine. I had none of the problems you mentioned. However, with the Link Units switch addition, I check all my settings before running anything after an upgrade.
I cut this using 2500mm/m, 95% power, 6 passes (always cuts through), and air assist.
Preview (3"x5" rectangle):
1000mm/m, 4 passes = 2min 40 sec
2500mm/m, 6 passes = 1min 37sec
More speed and more passes is often faster. 97% of the time, mine will cut clean in 5 passes. Pass #6 is for that other 3%. :rofl:
EDIT: Curious, you said less than 4 passes. I computed with 3 passes and still got 2 minutes.
This might have been asked but I am new here so sorry if I repeated someone else’s question. I have a wecreat 20w vision and installed the latest update. I did all the camera alignment and such and made it work, but the thing is does it only auto-focus in the center of the plate. I tried to put a board on the lower bottom left corner and just put a square to test it and when I auto-focus it, it goes to the center and try’s to focus there. But if i just play it, it will try too cut the piece in the corner but the machine is raised all the way up when it does that. When I try to frame it, it goes over the board but won’t go down and cut and if it does go down it just goes back up and try’s to cut.
