I upgraded my laser bed size to 889mmx889mm but now my laser seems to be misreading gcode
I upgraded my bed size for my sculpfun S30 from the standard size using one of their x and y extension kits. I have been using Lightburn flawlessly until this bed extensions upgrade. The problem is not a working space issue. But rather the laser seems un able to properly read the gcode. I am guessing this has something to do with software and not a mechanical issue but I am not sure. I will link some photos of the issue. This cut is something I have cut in the past without issue so I don’t believe the issue is in the drawing. Thank you for any help.
Photo 1
Photo 2
Hi Erik
Seems to me that your Y belts are quite loose.
Also, when you extended your bed, have you changed your $130 $131 values?
All rest should stay the same, specially Steps per mm, unless you also changed steppers.
Maybe it would help if you posted the output of the $$ command.
Console window → type $$ press enter
Scroll up and copy/paste the full output to here please.
I had a feeling it could be my y belts but it does the first cut fine but then seems to lose track of where the head is half way through the second cut. Thank you for your help.
Here is the output:
G0 X79.253Y460.488
G1 X70.617
G1 X79.253
G0 X79.253Y457.44
G1 X70.617
G1 X79.253
G0 X79.253Y454.392
G1 X70.617
G1 X79.253
G0 X79.253Y451.344
G1 X70.617
G1 X79.253
G0 X79.253Y448.296
G1 X70.617
G1 X79.253
G0 X79.253Y445.248
G1 X70.617
G1 X79.253
G0 X79.253Y442.2
G1 X70.617
G1 X79.253
G0 X79.253Y439.152
G1 X70.617
G1 X79.253
G0 X79.253Y436.104
G1 X70.617
G1 X79.253
G0 X79.253Y433.056
G1 X70.617
G1 X79.253
G0 X79.253Y430.008
G1 X70.617
G1 X79.253
G0 X79.253Y426.96
G1 X70.617
G1 X79.253
G0 X79.253Y423.912
G1 X70.617
G1 X79.253
G0 X79.253Y420.864
G1 X70.617
G1 X79.253
G0 X79.253Y417.816
G1 X70.617
G1 X79.253
G0 X79.253Y414.768
G1 X70.617
G1 X79.253
G0 X79.253Y411.72
G1 X70.617
G1 X79.253
G0 X79.253Y408.672
G1 X70.617
G1 X79.253
G0 X79.253Y405.624
G1 X70.617
G1 X79.253
G0 X79.253Y402.576
G1 X70.617
G1 X79.253
G0 X79.253Y399.528
G1 X70.617
G1 X79.253
G0 X79.253Y396.48
G1 X70.617
G1 X79.253
G0 X79.253Y393.432
G1 X70.617
G1 X79.253
G0 X79.253Y390.384
G1 X70.617
G1 X79.253
G0 X79.253Y387.336
G1 X70.617
G1 X79.253
G0 X79.253Y384.288
G1 X70.617
G1 X79.253
G0 X79.253Y381.24
G1 X70.617
G1 X79.253
G0 X79.253Y378.192
G1 X70.617
G1 X79.253
G0 X79.253Y375.144
G1 X70.617
G1 X79.253
G0 X79.253Y372.096
G1 X70.617
G1 X79.253
G0 X79.253Y369.048
G1 X70.617
G1 X79.253
G0 X79.253Y366
G1 X70.617
G1 X79.253
G0 X79.253Y362.952
G1 X70.617
G1 X79.253
G0 X79.253Y359.904
G1 X70.617
G1 X79.253
G0 X79.253Y356.856
G1 X70.617
G1 X79.253
G0 X79.253Y353.808
G1 X70.617
G1 X79.253
G0 X79.253Y350.76
G1 X70.617
G1 X79.253
G0 X84.587Y352.284
G1 X75.951
G1 X84.587
G0 X84.587Y355.332
G1 X75.951
G1 X84.587
G0 X84.587Y358.38
G1 X75.951
G1 X84.587
G0 X84.587Y361.428
G1 X75.951
G1 X84.587
G0 X84.587Y364.476
G1 X75.951
G1 X84.587
G0 X84.587Y367.524
G1 X75.951
G1 X84.587
G0 X84.587Y370.572
G1 X75.951
G1 X84.587
G0 X84.587Y373.62
G1 X75.951
G1 X84.587
G0 X84.587Y376.668
G1 X75.951
G1 X84.587
G0 X84.587Y379.716
G1 X75.951
G1 X84.587
G0 X84.587Y382.764
G1 X75.951
G1 X84.587
G0 X84.587Y385.812
G1 X75.951
G1 X84.587
G0 X84.587Y388.86
G1 X75.951
G1 X84.587
G0 X84.587Y391.908
G1 X75.951
G1 X84.587
G0 X84.587Y394.956
G1 X75.951
G1 X84.587
G0 X84.587Y398.004
G1 X75.951
G1 X84.587
G0 X84.587Y401.052
G1 X75.951
G1 X84.587
G0 X84.587Y404.1
G1 X75.951
G1 X84.587
G0 X84.587Y407.148
G1 X75.951
G1 X84.587
G0 X84.587Y410.196
G1 X75.951
G1 X84.587
G0 X84.587Y413.244
G1 X75.951
G1 X84.587
G0 X84.587Y416.292
G1 X75.951
G1 X84.587
G0 X84.587Y419.34
G1 X75.951
G1 X84.587
G0 X84.587Y422.388
G1 X75.951
G1 X84.587
G0 X84.587Y425.436
G1 X75.951
G1 X84.587
G0 X84.587Y428.484
G1 X75.951
G1 X84.587
G0 X84.587Y431.532
G1 X75.951
G1 X84.587
G0 X84.587Y434.58
G1 X75.951
G1 X84.587
G0 X84.587Y437.628
G1 X75.951
G1 X84.587
G0 X84.587Y440.676
G1 X75.951
G1 X84.587
G0 X84.587Y443.724
G1 X75.951
G1 X84.587
G0 X84.587Y446.772
G1 X75.951
G1 X84.587
G0 X84.587Y449.82
G1 X75.951
G1 X84.587
G0 X84.587Y452.868
G1 X75.951
G1 X84.587
G0 X84.587Y455.916
G1 X75.951
G1 X84.587
G0 X84.587Y458.964
G1 X75.951
G1 X84.587
G0 X84.587Y462.012
G1 X75.951
G1 X84.587
G0 X84.587Y465.06
G1 X75.951
G1 X84.587
G0 X84.587Y468.108
G1 X75.951
G1 X84.587
G0 X84.587Y471.156
G1 X75.951
G1 X84.587
G0 X84.587Y474.204
G1 X75.951
G1 X84.587
G0 X84.587Y477.252
G1 X75.951
G1 X84.587
G0 X84.587Y480.3
G1 X75.951
G1 X84.587
G0 X84.587Y483.348
G1 X75.951
G1 X84.587
G0 X84.587Y486.396
G1 X75.951
G1 X84.587
G0 X84.587Y489.444
G1 X75.951
G1 X84.587
G0 X84.587Y492.492
G1 X75.951
G1 X84.587
G0 X89.921Y490.968
G1 X81.285
G1 X89.921
G0 X89.921Y487.92
G1 X81.285
G1 X89.921
G0 X89.921Y484.872
G1 X81.285
G1 X89.921
G0 X89.921Y481.824
G1 X81.285
G1 X89.921
G0 X89.921Y478.776
G1 X81.285
G1 X89.921
G0 X89.921Y475.728
G1 X81.285
G1 X89.921
G0 X89.921Y472.68
G1 X81.285
G1 X89.921
G0 X89.921Y469.632
G1 X81.285
G1 X89.921
G0 X89.921Y466.584
G1 X81.285
G1 X89.921
G0 X89.921Y463.536
G1 X81.285
G1 X89.921
G0 X89.357Y462.012
G1 X80.721
G1 X89.357
G0 X95.255Y462.012
G1 X86.619
G1 X95.255
G0 X95.255Y458.964
G1 X86.619
G1 X95.255
G0 X95.255Y455.916
G1 X86.619
G1 X95.255
G0 X95.255Y452.868
G1 X86.619
G1 X95.255
G0 X95.255Y449.82
G1 X86.619
G1 X95.255
G0 X95.255Y446.772
G1 X86.619
G1 X95.255
G0 X95.255Y443.724
G1 X86.619
G1 X95.255
G0 X95.255Y440.676
G1 X86.619
G1 X95.255
G0 X95.255Y437.628
G1 X86.619
G1 X95.255
G0 X95.255Y434.58
G1 X86.619
G1 X95.255
G0 X95.255Y431.532
G1 X86.619
G1 X95.255
G0 X95.255Y428.484
G1 X86.619
G1 X95.255
G0 X95.255Y425.436
G1 X86.619
G1 X95.255
G0 X95.255Y422.388
G1 X86.619
G1 X95.255
G0 X95.255Y419.34
G1 X86.619
G1 X95.255
G0 X95.255Y416.292
G1 X86.619
G1 X95.255
G0 X95.255Y413.244
G1 X86.619
G1 X95.255
G0 X95.255Y410.196
G1 X86.619
G1 X95.255
G0 X95.255Y407.148
G1 X86.619
G1 X95.255
G0 X95.255Y404.1
G1 X86.619
G1 X95.255
G0 X95.255Y401.052
G1 X86.619
G1 X95.255
G0 X95.255Y398.004
G1 X86.619
G1 X95.255
G0 X95.255Y394.956
G1 X86.619
G1 X95.255
G0 X95.255Y391.908
G1 X86.619
G1 X95.255
G0 X95.255Y388.86
G1 X86.619
G1 X95.255
G0 X95.255Y385.812
G1 X86.619
G1 X95.255
G0 X95.255Y382.764
G1 X86.619
G1 X95.255
G0 X95.255Y379.716
G1 X86.619
G1 X95.255
G0 X95.255Y376.668
G1 X86.619
G1 X95.255
G0 X95.255Y373.62
G1 X86.619
G1 X95.255
G0 X95.255Y370.572
G1 X86.619
G1 X95.255
G0 X95.255Y367.524
G1 X86.619
G1 X95.255
G0 X95.255Y364.476
G1 X86.619
G1 X95.255
G0 X95.255Y361.428
G1 X86.619
G1 X95.255
G0 X95.255Y358.38
G1 X86.619
G1 X95.255
G0 X95.255Y355.332
G1 X86.619
G1 X95.255
G0 X95.255Y352.284
G1 X86.619
G1 X95.255
G0 X89.921Y350.76
G1 X81.285
G1 X89.921
G0 X89.921Y353.808
G1 X81.285
G1 X89.921
G0 X89.921Y356.856
G1 X81.285
G1 X89.921
G0 X89.921Y359.904
G1 X81.285
G1 X89.921
G0 X89.921Y362.952
G1 X81.285
G1 X89.921
G0 X89.921Y366
G1 X81.285
G1 X89.921
G0 X89.921Y369.048
G1 X81.285
G1 X89.921
G0 X89.921Y372.096
G1 X81.285
G1 X89.921
G0 X89.921Y375.144
G1 X81.285
G1 X89.921
G0 X89.921Y378.192
G1 X81.285
G1 X89.921
G0 X89.921Y381.24
G1 X81.285
G1 X89.921
G0 X89.921Y384.288
G1 X81.285
G1 X89.921
G0 X89.921Y387.336
G1 X81.285
G1 X89.921
G0 X89.921Y390.384
G1 X81.285
G1 X89.921
G0 X89.921Y393.432
G1 X81.285
G1 X89.921
G0 X89.921Y396.48
G1 X81.285
G1 X89.921
G0 X89.921Y399.528
G1 X81.285
G1 X89.921
G0 X89.921Y402.576
G1 X81.285
G1 X89.921
G0 X89.921Y405.624
G1 X81.285
G1 X89.921
G0 X89.921Y408.672
G1 X81.285
G1 X89.921
G0 X89.921Y411.72
G1 X81.285
G1 X89.921
G0 X89.921Y414.768
G1 X81.285
G1 X89.921
G0 X89.921Y417.816
G1 X81.285
G1 X89.921
G0 X89.921Y420.864
G1 X81.285
G1 X89.921
G0 X89.921Y423.912
G1 X81.285
G1 X89.921
G0 X89.921Y426.96
G1 X81.285
G1 X89.921
G0 X89.921Y430.008
G1 X81.285
G1 X89.921
G0 X89.921Y433.056
G1 X81.285
G1 X89.921
G0 X89.921Y436.104
G1 X81.285
G1 X89.921
G0 X89.921Y439.152
G1 X81.285
G1 X89.921
G0 X89.921Y442.2
G1 X81.285
G1 X89.921
G0 X89.921Y445.248
G1 X81.285
G1 X89.921
G0 X89.921Y448.296
G1 X81.285
G1 X89.921
G0 X89.921Y451.344
G1 X81.285
G1 X89.921
G0 X89.921Y454.392
G1 X81.285
G1 X89.921
G0 X89.921Y457.44
G1 X81.285
G1 X89.921
G0 X100.589Y457.44
G1 X91.953
G1 X100.589
G0 X100.589Y454.392
G1 X91.953
G1 X100.589
G0 X100.589Y451.344
G1 X91.953
G1 X100.589
G0 X100.589Y448.296
G1 X91.953
G1 X100.589
G0 X100.589Y445.248
G1 X91.953
G1 X100.589
G0 X100.589Y442.2
G1 X91.953
G1 X100.589
G0 X100.589Y439.152
G1 X91.953
G1 X100.589
G0 X100.589Y436.104
G1 X91.953
G1 X100.589
G0 X100.589Y433.056
G1 X91.953
G1 X100.589
G0 X100.589Y430.008
G1 X91.953
G1 X100.589
G0 X100.589Y426.96
G1 X91.953
G1 X100.589
G0 X100.589Y423.912
G1 X91.953
G1 X100.589
G0 X100.589Y420.864
G1 X91.953
G1 X100.589
G0 X100.589Y417.816
G1 X91.953
G1 X100.589
G0 X100.589Y414.768
G1 X91.953
G1 X100.589
G0 X100.589Y411.72
G1 X91.953
G1 X100.589
G0 X100.589Y408.672
G1 X91.953
G1 X100.589
G0 X100.589Y405.624
G1 X91.953
G1 X100.589
G0 X100.589Y402.576
G1 X91.953
G1 X100.589
G0 X100.589Y399.528
G1 X91.953
G1 X100.589
G0 X100.589Y396.48
G1 X91.953
G1 X100.589
G0 X100.589Y393.432
G1 X91.953
G1 X100.589
G0 X100.589Y390.384
G1 X91.953
G1 X100.589
G0 X100.589Y387.336
G1 X91.953
G1 X100.589
G0 X100.589Y384.288
G1 X91.953
G1 X100.589
G0 X100.589Y381.24
G1 X91.953
G1 X100.589
G0 X100.589Y378.192
G1 X91.953
G1 X100.589
G0 X100.589Y375.144
G1 X91.953
G1 X100.589
G0 X100.589Y372.096
G1 X91.953
G1 X100.589
G0 X100.589Y369.048
G1 X91.953
G1 X100.589
G0 X100.589Y366
G1 X91.953
G1 X100.589
G0 X100.589Y362.952
G1 X91.953
G1 X100.589
G0 X100.589Y359.904
G1 X91.953
G1 X100.589
G0 X100.589Y356.856
G1 X91.953
G1 X100.589
G0 X100.589Y353.808
G1 X91.953
G1 X100.589
G0 X100.589Y350.76
G1 X91.953
G1 X100.589
G0 X105.923Y352.284
G1 X97.287
G1 X105.923
G0 X105.923Y355.332
G1 X97.287
G1 X105.923
G0 X105.923Y358.38
G1 X97.287
G1 X105.923
G0 X105.923Y361.428
G1 X97.287
G1 X105.923
G0 X105.923Y364.476
G1 X97.287
G1 X105.923
G0 X105.923Y367.524
G1 X97.287
G1 X105.923
G0 X105.923Y370.572
G1 X97.287
G1 X105.923
G0 X105.923Y373.62
G1 X97.287
G1 X105.923
G0 X105.923Y376.668
G1 X97.287
G1 X105.923
G0 X105.923Y379.716
G1 X97.287
G1 X105.923
G0 X105.923Y382.764
G1 X97.287
G1 X105.923
G0 X105.923Y385.812
G1 X97.287
G1 X105.923
G0 X105.923Y388.86
G1 X97.287
G1 X105.923
G0 X105.923Y391.908
G1 X97.287
G1 X105.923
G0 X105.923Y394.956
G1 X97.287
G1 X105.923
G0 X105.923Y398.004
G1 X97.287
G1 X105.923
G0 X105.923Y401.052
G1 X97.287
G1 X105.923
G0 X105.923Y404.1
G1 X97.287
G1 X105.923
G0 X105.923Y407.148
G1 X97.287
G1 X105.923
G0 X105.923Y410.196
G1 X97.287
G1 X105.923
G0 X105.923Y413.244
G1 X97.287
G1 X105.923
G0 X105.923Y416.292
G1 X97.287
G1 X105.923
G0 X105.923Y419.34
G1 X97.287
G1 X105.923
G0 X105.923Y422.388
G1 X97.287
G1 X105.923
G0 X105.923Y425.436
G1 X97.287
G1 X105.923
G0 X105.923Y428.484
G1 X97.287
G1 X105.923
G0 X105.923Y431.532
G1 X97.287
G1 X105.923
G0 X105.923Y434.58
G1 X97.287
G1 X105.923
G0 X105.923Y437.628
G1 X97.287
G1 X105.923
G0 X105.923Y440.676
G1 X97.287
G1 X105.923
G0 X105.923Y443.724
G1 X97.287
G1 X105.923
G0 X105.923Y446.772
G1 X97.287
G1 X105.923
G0 X105.923Y449.82
G1 X97.287
G1 X105.923
G0 X105.923Y452.868
G1 X97.287
G1 X105.923
G0 X105.923Y455.916
G1 X97.287
G1 X105.923
G0 X105.923Y458.964
G1 X97.287
G1 X105.923
G0 X105.923Y462.012
G1 X97.287
G1 X105.923
G0 X105.923Y465.06
G1 X97.287
G1 X105.923
G0 X105.923Y468.108
G1 X97.287
G1 X105.923
G0 X105.923Y471.156
G1 X97.287
G1 X105.923
G0 X105.923Y474.204
G1 X97.287
G1 X105.923
G0 X105.923Y477.252
G1 X97.287
G1 X105.923
G0 X105.923Y480.3
G1 X97.287
G1 X105.923
G0 X105.923Y483.348
G1 X97.287
G1 X105.923
G0 X105.923Y486.396
G1 X97.287
G1 X105.923
G0 X105.923Y489.444
G1 X97.287
G1 X105.923
G0 X105.923Y492.492
G1 X97.287
G1 X105.923
G0 X100.589Y490.968
G1 X91.953
G1 X100.589
G0 X100.589Y487.92
G1 X91.953
G1 X100.589
G0 X100.589Y484.872
G1 X91.953
G1 X100.589
G0 X100.589Y481.824
G1 X91.953
G1 X100.589
G0 X100.589Y478.776
G1 X91.953
G1 X100.589
G0 X100.589Y475.728
G1 X91.953
G1 X100.589
G0 X100.589Y472.68
G1 X91.953
G1 X100.589
G0 X100.589Y469.632
G1 X91.953
G1 X100.589
G0 X100.589Y466.584
G1 X91.953
G1 X100.589
G0 X100.589Y463.536
G1 X91.953
G1 X100.589
G0 X100.589Y460.488
G1 X91.953
G1 X100.589
G0 X95.255Y465.06
G1 X86.619
G1 X95.255
G0 X95.255Y468.108
G1 X86.619
G1 X95.255
G0 X95.255Y471.156
G1 X86.619
G1 X95.255
G0 X95.255Y474.204
G1 X86.619
G1 X95.255
G0 X95.255Y477.252
G1 X86.619
G1 X95.255
G0 X95.255Y480.3
G1 X86.619
G1 X95.255
G0 X95.255Y483.348
G1 X86.619
G1 X95.255
G0 X95.255Y486.396
G1 X86.619
G1 X95.255
G0 X95.255Y489.444
G1 X86.619
G1 X95.255
G0 X95.255Y492.492
G1 X86.619
G1 X95.255
G0 X111.257Y490.968
G1 X102.621
G1 X111.257
G0 X111.257Y487.92
G1 X102.621
G1 X111.257
G0 X111.257Y484.872
G1 X102.621
G1 X111.257
G0 X111.257Y481.824
G1 X102.621
G1 X111.257
G0 X111.257Y478.776
G1 X102.621
G1 X111.257
G0 X111.257Y475.728
G1 X102.621
G1 X111.257
G0 X111.257Y472.68
G1 X102.621
G1 X111.257
G0 X111.257Y469.632
G1 X102.621
G1 X111.257
G0 X111.257Y466.584
G1 X102.621
G1 X111.257
G0 X111.257Y463.536
G1 X102.621
G1 X111.257
G0 X111.257Y460.488
G1 X102.621
G1 X111.257
G0 X111.257Y457.44
G1 X102.621
G1 X111.257
G0 X111.257Y454.392
G1 X102.621
G1 X111.257
G0 X111.257Y451.344
G1 X102.621
G1 X111.257
G0 X111.257Y448.296
G1 X102.621
G1 X111.257
G0 X111.257Y445.248
G1 X102.621
G1 X111.257
G0 X111.257Y442.2
G1 X102.621
G1 X111.257
G0 X111.257Y439.152
G1 X102.621
G1 X111.257
G0 X111.257Y436.104
G1 X102.621
G1 X111.257
G0 X111.257Y433.056
G1 X102.621
G1 X111.257
G0 X111.257Y430.008
G1 X102.621
G1 X111.257
G0 X111.257Y426.96
G1 X102.621
G1 X111.257
G0 X111.257Y423.912
G1 X102.621
G1 X111.257
G0 X111.257Y420.864
G1 X102.621
G1 X111.257
G0 X111.257Y417.816
G1 X102.621
G1 X111.257
G0 X111.257Y414.768
G1 X102.621
G1 X111.257
G0 X111.257Y411.72
G1 X102.621
G1 X111.257
G0 X111.257Y408.672
G1 X102.621
G1 X111.257
G0 X111.257Y405.624
G1 X102.621
G1 X111.257
G0 X111.257Y402.576
G1 X102.621
G1 X111.257
G0 X111.257Y399.528
G1 X102.621
G1 X111.257
G0 X111.257Y396.48
G1 X102.621
G1 X111.257
G0 X111.257Y393.432
G1 X102.621
G1 X111.257
G0 X111.257Y390.384
G1 X102.621
G1 X111.257
G0 X111.257Y387.336
G1 X102.621
G1 X111.257
G0 X111.257Y384.288
G1 X102.621
G1 X111.257
G0 X111.257Y381.24
G1 X102.621
G1 X111.257
G0 X111.257Y378.192
G1 X102.621
G1 X111.257
G0 X111.257Y375.144
G1 X102.621
G1 X111.257
G0 X111.257Y372.096
G1 X102.621
G1 X111.257
G0 X111.257Y369.048
G1 X102.621
G1 X111.257
G0 X111.257Y366
G1 X102.621
G1 X111.257
G0 X111.257Y362.952
G1 X102.621
G1 X111.257
G0 X111.257Y359.904
G1 X102.621
G1 X111.257
G0 X111.257Y356.856
G1 X102.621
G1 X111.257
G0 X111.257Y353.808
G1 X102.621
G1 X111.257
G0 X111.257Y350.76
G1 X102.621
G1 X111.257
G0 X116.591Y352.284
G1 X107.955
G1 X116.591
G0 X116.591Y355.332
G1 X107.955
G1 X116.591
G0 X116.591Y358.38
G1 X107.955
G1 X116.591
G0 X116.591Y361.428
G1 X107.955
G1 X116.591
G0 X116.591Y364.476
G1 X107.955
G1 X116.591
G0 X116.591Y367.524
G1 X107.955
G1 X116.591
G0 X116.591Y370.572
G1 X107.955
G1 X116.591
G0 X116.591Y373.62
G1 X107.955
G1 X116.591
G0 X116.591Y376.668
G1 X107.955
G1 X116.591
G0 X116.591Y379.716
G1 X107.955
G1 X116.591
G0 X116.591Y382.764
G1 X107.955
G1 X116.591
G0 X116.591Y385.812
G1 X107.955
G1 X116.591
G0 X116.591Y388.86
G1 X107.955
G1 X116.591
G0 X116.591Y391.908
G1 X107.955
G1 X116.591
G0 X116.591Y394.956
G1 X107.955
G1 X116.591
G0 X116.591Y398.004
G1 X107.955
G1 X116.591
G0 X116.591Y401.052
G1 X107.955
G1 X116.591
G0 X116.591Y404.1
G1 X107.955
G1 X116.591
G0 X116.591Y407.148
G1 X107.955
G1 X116.591
G0 X116.591Y410.196
G1 X107.955
G1 X116.591
G0 X116.591Y413.244
G1 X107.955
G1 X116.591
G0 X116.591Y416.292
G1 X107.955
G1 X116.591
G0 X116.591Y419.34
G1 X107.955
G1 X116.591
G0 X116.591Y422.388
G1 X107.955
G1 X116.591
G0 X116.591Y425.436
G1 X107.955
G1 X116.591
G0 X116.591Y428.484
G1 X107.955
G1 X116.591
G0 X116.591Y431.532
G1 X107.955
G1 X116.591
G0 X116.591Y434.58
G1 X107.955
G1 X116.591
G0 X116.591Y437.628
G1 X107.955
G1 X116.591
G0 X116.591Y440.676
G1 X107.955
G1 X116.591
G0 X116.591Y443.724
G1 X107.955
G1 X116.591
G0 X116.591Y446.772
G1 X107.955
G1 X116.591
G0 X116.591Y449.82
G1 X107.955
G1 X116.591
G0 X116.591Y452.868
G1 X107.955
G1 X116.591
G0 X116.591Y455.916
G1 X107.955
G1 X116.591
G0 X116.591Y458.964
G1 X107.955
G1 X116.591
G0 X116.591Y462.012
G1 X107.955
G1 X116.591
G0 X116.591Y465.06
G1 X107.955
G1 X116.591
G0 X116.591Y468.108
G1 X107.955
G1 X116.591
G0 X116.591Y471.156
G1 X107.955
G1 X116.591
G0 X116.591Y474.204
G1 X107.955
G1 X116.591
G0 X116.591Y477.252
G1 X107.955
G1 X116.591
G0 X116.591Y480.3
G1 X107.955
G1 X116.591
G0 X116.591Y483.348
G1 X107.955
G1 X116.591
G0 X116.591Y486.396
G1 X107.955
G1 X116.591
G0 X116.591Y489.444
G1 X107.955
G1 X116.591
G0 X116.591Y492.492
G1 X107.955
G1 X116.591
G0 X121.925Y490.968
G1 X113.289
G1 X121.925
G0 X121.925Y487.92
G1 X113.289
G1 X121.925
G0 X121.925Y484.872
G1 X113.289
G1 X121.925
G0 X121.925Y481.824
G1 X113.289
G1 X121.925
G0 X121.925Y478.776
G1 X113.289
G1 X121.925
G0 X121.925Y475.728
G1 X113.289
G1 X121.925
G0 X121.925Y472.68
G1 X113.289
G1 X121.925
G0 X121.925Y469.632
G1 X113.289
G1 X121.925
G0 X121.925Y466.584
G1 X113.289
G1 X121.925
G0 X121.925Y463.536
G1 X113.289
G1 X121.925
G0 X121.925Y460.488
G1 X113.289
G1 X121.925
G0 X121.925Y457.44
G1 X113.289
G1 X121.925
G0 X121.925Y454.392
G1 X113.289
G1 X121.925
G0 X121.925Y451.344
G1 X113.289
G1 X121.925
G0 X121.925Y448.296
G1 X113.289
G1 X121.925
G0 X121.925Y445.248
G1 X113.289
G1 X121.925
G0 X121.925Y442.2
G1 X113.289
G1 X121.925
G0 X121.925Y439.152
G1 X113.289
G1 X121.925
G0 X121.925Y436.104
G1 X113.289
G1 X121.925
G0 X121.925Y433.056
G1 X113.289
G1 X121.925
G0 X121.925Y430.008
G1 X113.289
G1 X121.925
G0 X121.925Y426.96
G1 X113.289
G1 X121.925
G0 X121.925Y423.912
G1 X113.289
G1 X121.925
G0 X121.925Y420.864
G1 X113.289
G1 X121.925
G0 X121.925Y417.816
G1 X113.289
G1 X121.925
G0 X121.925Y414.768
G1 X113.289
G1 X121.925
G0 X121.925Y411.72
G1 X113.289
G1 X121.925
G0 X121.925Y408.672
G1 X113.289
G1 X121.925
G0 X121.925Y405.624
G1 X113.289
G1 X121.925
G0 X121.925Y402.576
G1 X113.289
G1 X121.925
G0 X121.925Y399.528
G1 X113.289
G1 X121.925
G0 X121.925Y396.48
G1 X113.289
G1 X121.925
G0 X121.925Y393.432
G1 X113.289
G1 X121.925
G0 X121.925Y390.384
G1 X113.289
G1 X121.925
G0 X121.925Y387.336
G1 X113.289
G1 X121.925
G0 X121.925Y384.288
G1 X113.289
G1 X121.925
G0 X121.925Y381.24
G1 X113.289
G1 X121.925
G0 X121.925Y378.192
G1 X113.289
G1 X121.925
G0 X121.925Y375.144
G1 X113.289
G1 X121.925
G0 X121.925Y372.096
G1 X113.289
G1 X121.925
G0 X121.925Y369.048
G1 X113.289
G1 X121.925
G0 X121.925Y366
G1 X113.289
G1 X121.925
G0 X121.925Y362.952
G1 X113.289
G1 X121.925
G0 X121.925Y359.904
G1 X113.289
G1 X121.925
G0 X121.925Y356.856
G1 X113.289
G1 X121.925
G0 X121.925Y353.808
G1 X113.289
G1 X121.925
G0 X121.925Y350.76
G1 X113.289
G1 X121.925
G0 X127.259Y352.284
G1 X118.623
G1 X127.259
G0 X127.259Y355.332
G1 X118.623
G1 X127.259
G0 X127.259Y358.38
G1 X118.623
G1 X127.259
G0 X127.259Y361.428
G1 X118.623
G1 X127.259
G0 X127.259Y364.476
G1 X118.623
G1 X127.259
G0 X127.259Y367.524
G1 X118.623
G1 X127.259
G0 X127.259Y370.572
G1 X118.623
G1 X127.259
G0 X127.259Y373.62
G1 X118.623
G1 X127.259
G0 X127.259Y376.668
G1 X118.623
G1 X127.259
G0 X127.259Y379.716
G1 X118.623
G1 X127.259
G0 X127.259Y382.764
G1 X118.623
G1 X127.259
G0 X127.259Y385.812
G1 X118.623
G1 X127.259
G0 X127.259Y388.86
G1 X118.623
G1 X127.259
G0 X127.259Y391.908
G1 X118.623
G1 X127.259
G0 X127.259Y394.956
G1 X118.623
G1 X127.259
G0 X127.259Y398.004
G1 X118.623
G1 X127.259
G0 X127.259Y401.052
G1 X118.623
G1 X127.259
G0 X127.259Y404.1
G1 X118.623
G1 X127.259
G0 X127.259Y407.148
G1 X118.623
G1 X127.259
G0 X127.259Y410.196
G1 X118.623
G1 X127.259
G0 X127.259Y413.244
G1 X118.623
G1 X127.259
G0 X127.259Y416.292
G1 X118.623
G1 X127.259
G0 X127.259Y419.34
G1 X118.623
G1 X127.259
G0 X127.259Y422.388
G1 X118.623
G1 X127.259
G0 X127.259Y425.436
G1 X118.623
G1 X127.259
G0 X127.259Y428.484
G1 X118.623
G1 X127.259
G0 X127.259Y431.532
G1 X118.623
G1 X127.259
G0 X127.259Y434.58
G1 X118.623
G1 X127.259
G0 X127.259Y437.628
G1 X118.623
G1 X127.259
G0 X127.259Y440.676
G1 X118.623
G1 X127.259
G0 X127.259Y443.724
G1 X118.623
G1 X127.259
G0 X127.259Y446.772
G1 X118.623
G1 X127.259
G0 X127.259Y449.82
G1 X118.623
G1 X127.259
G0 X127.259Y452.868
G1 X118.623
G1 X127.259
G0 X127.259Y455.916
G1 X118.623
G1 X127.259
G0 X127.259Y458.964
G1 X118.623
G1 X127.259
G0 X127.259Y462.012
G1 X118.623
G1 X127.259
G0 X127.259Y465.06
G1 X118.623
G1 X127.259
G0 X127.259Y468.108
G1 X118.623
G1 X127.259
G0 X127.259Y471.156
G1 X118.623
G1 X127.259
G0 X127.259Y474.204
G1 X118.623
G1 X127.259
G0 X127.259Y477.252
G1 X118.623
G1 X127.259
G0 X127.259Y480.3
G1 X118.623
G1 X127.259
G0 X127.259Y483.348
G1 X118.623
G1 X127.259
G0 X127.259Y486.396
G1 X118.623
G1 X127.259
G0 X127.259Y489.444
G1 X118.623
G1 X127.259
G0 X127.259Y492.492
G1 X118.623
G1 X127.259
G0 X132.593Y490.968
G1 X123.957
G1 X132.593
G0 X132.593Y487.92
G1 X123.957
G1 X132.593
G0 X132.593Y484.872
G1 X123.957
G1 X132.593
G0 X132.593Y481.824
G1 X123.957
G1 X132.593
G0 X132.593Y478.776
G1 X123.957
G1 X132.593
G0 X132.593Y475.728
G1 X123.957
G1 X132.593
G0 X132.593Y472.68
G1 X123.957
G1 X132.593
G0 X132.593Y469.632
G1 X123.957
G1 X132.593
G0 X132.593Y466.584
G1 X123.957
G1 X132.593
G0 X132.593Y463.536
G1 X123.957
G1 X132.593
G0 X132.593Y460.488
G1 X123.957
G1 X132.593
G0 X132.593Y457.44
G1 X123.957
G1 X132.593
G0 X132.593Y454.392
G1 X123.957
G1 X132.593
G0 X132.593Y451.344
G1 X123.957
G1 X132.593
G0 X132.593Y448.296
G1 X123.957
G1 X132.593
G0 X132.593Y445.248
G1 X123.957
G1 X132.593
G0 X132.593Y442.2
G1 X123.957
G1 X132.593
G0 X132.593Y439.152
G1 X123.957
G1 X132.593
G0 X132.593Y436.104
G1 X123.957
G1 X132.593
G0 X132.593Y433.056
G1 X123.957
G1 X132.593
G0 X132.593Y430.008
G1 X123.957
G1 X132.593
G0 X132.593Y426.96
G1 X123.957
G1 X132.593
G0 X132.593Y423.912
G1 X123.957
G1 X132.593
G0 X132.593Y420.864
G1 X123.957
G1 X132.593
G0 X132.593Y417.816
G1 X123.957
G1 X132.593
G0 X132.593Y414.768
G1 X123.957
G1 X132.593
G0 X132.593Y411.72
G1 X123.957
G1 X132.593
G0 X132.593Y408.672
G1 X123.957
G1 X132.593
G0 X132.593Y405.624
G1 X123.957
G1 X132.593
G0 X132.593Y402.576
G1 X123.957
G1 X132.593
G0 X132.593Y399.528
G1 X123.957
G1 X132.593
G0 X132.593Y396.48
G1 X123.957
G1 X132.593
G0 X132.593Y393.432
G1 X123.957
G1 X132.593
G0 X132.593Y390.384
G1 X123.957
G1 X132.593
G0 X132.593Y387.336
G1 X123.957
G1 X132.593
G0 X132.593Y384.288
G1 X123.957
G1 X132.593
G0 X132.593Y381.24
G1 X123.957
G1 X132.593
G0 X132.593Y378.192
G1 X123.957
G1 X132.593
G0 X132.593Y375.144
G1 X123.957
G1 X132.593
G0 X132.593Y372.096
G1 X123.957
G1 X132.593
G0 X132.593Y369.048
G1 X123.957
G1 X132.593
G0 X132.593Y366
G1 X123.957
G1 X132.593
G0 X132.593Y362.952
G1 X123.957
G1 X132.593
G0 X132.593Y359.904
G1 X123.957
G1 X132.593
G0 X132.593Y356.856
G1 X123.957
G1 X132.593
G0 X132.593Y353.808
G1 X123.957
G1 X132.593
G0 X132.593Y350.76
G1 X123.957
G1 X132.593
G0 X137.927Y352.284
G1 X129.291
G1 X137.927
G0 X137.927Y355.332
G1 X129.291
G1 X137.927
G0 X137.927Y358.38
G1 X129.291
G1 X137.927
G0 X137.927Y361.428
G1 X129.291
G1 X137.927
G0 X137.927Y364.476
G1 X129.291
G1 X137.927
G0 X137.927Y367.524
G1 X129.291
G1 X137.927
G0 X137.927Y370.572
G1 X129.291
G1 X137.927
G0 X137.927Y373.62
G1 X129.291
G1 X137.927
G0 X137.927Y376.668
G1 X129.291
G1 X137.927
G0 X137.927Y379.716
G1 X129.291
G1 X137.927
G0 X137.927Y382.764
G1 X129.291
G1 X137.927
G0 X137.927Y385.812
G1 X129.291
G1 X137.927
G0 X137.927Y388.86
G1 X129.291
G1 X137.927
G0 X137.927Y391.908
G1 X129.291
G1 X137.927
G0 X137.927Y394.956
G1 X129.291
G1 X137.927
G0 X137.927Y398.004
G1 X129.291
G1 X137.927
G0 X137.927Y401.052
G1 X129.291
G1 X137.927
G0 X137.927Y404.1
G1 X129.291
G1 X137.927
G0 X137.927Y407.148
G1 X129.291
G1 X137.927
G0 X137.927Y410.196
G1 X129.291
G1 X137.927
G0 X137.927Y413.244
G1 X129.291
G1 X137.927
G0 X137.927Y416.292
G1 X129.291
G1 X137.927
G0 X137.927Y419.34
G1 X129.291
G1 X137.927
G0 X137.927Y422.388
G1 X129.291
G1 X137.927
G0 X137.927Y425.436
G1 X129.291
G1 X137.927
G0 X137.927Y428.484
G1 X129.291
G1 X137.927
G0 X137.927Y431.532
G1 X129.291
G1 X137.927
G0 X137.927Y434.58
G1 X129.291
G1 X137.927
G0 X137.927Y437.628
G1 X129.291
G1 X137.927
G0 X137.927Y440.676
G1 X129.291
G1 X137.927
G0 X137.927Y443.724
G1 X129.291
G1 X137.927
G0 X137.927Y446.772
G1 X129.291
G1 X137.927
G0 X137.927Y449.82
G1 X129.291
G1 X137.927
G0 X137.927Y452.868
G1 X129.291
G1 X137.927
G0 X137.927Y455.916
G1 X129.291
G1 X137.927
G0 X137.927Y458.964
G1 X129.291
G1 X137.927
G0 X137.927Y462.012
G1 X129.291
G1 X137.927
G0 X137.927Y465.06
G1 X129.291
G1 X137.927
G0 X137.927Y468.108
G1 X129.291
G1 X137.927
G0 X137.927Y471.156
G1 X129.291
G1 X137.927
G0 X137.927Y474.204
G1 X129.291
G1 X137.927
G0 X137.927Y477.252
G1 X129.291
G1 X137.927
G0 X137.927Y480.3
G1 X129.291
G1 X137.927
G0 X137.927Y483.348
G1 X129.291
G1 X137.927
G0 X137.927Y486.396
G1 X129.291
G1 X137.927
G0 X137.927Y489.444
G1 X129.291
G1 X137.927
G0 X137.927Y492.492
G1 X129.291
G1 X137.927
G0 X143.261Y490.968
G1 X134.625
G1 X143.261
G0 X143.261Y487.92
G1 X134.625
G1 X143.261
G0 X143.261Y484.872
G1 X134.625
G1 X143.261
G0 X143.261Y481.824
G1 X134.625
G1 X143.261
G0 X143.261Y478.776
G1 X134.625
G1 X143.261
G0 X143.261Y475.728
G1 X134.625
G1 X143.261
G0 X143.261Y472.68
G1 X134.625
G1 X143.261
G0 X143.261Y469.632
G1 X134.625
G1 X143.261
G0 X143.261Y466.584
G1 X134.625
G1 X143.261
G0 X143.261Y463.536
G1 X134.625
G1 X143.261
G0 X143.261Y460.488
G1 X134.625
G1 X143.261
G0 X143.261Y457.44
G1 X134.625
G1 X143.261
G0 X143.261Y454.392
G1 X134.625
G1 X143.261
G0 X143.261Y451.344
G1 X134.625
G1 X143.261
G0 X143.261Y448.296
G1 X134.625
G1 X143.261
G0 X143.261Y445.248
G1 X134.625
G1 X143.261
G0 X143.261Y442.2
G1 X134.625
G1 X143.261
G0 X143.261Y439.152
G1 X134.625
G1 X143.261
G0 X143.261Y436.104
G1 X134.625
G1 X143.261
G0 X143.261Y433.056
G1 X134.625
G1 X143.261
G0 X143.261Y430.008
G1 X134.625
G1 X143.261
G0 X143.261Y426.96
G1 X134.625
G1 X143.261
G0 X143.261Y423.912
G1 X134.625
G1 X143.261
G0 X143.261Y420.864
G1 X134.625
G1 X143.261
G0 X143.261Y417.816
G1 X134.625
G1 X143.261
G0 X143.261Y414.768
G1 X134.625
G1 X143.261
G0 X143.261Y411.72
G1 X134.625
G1 X143.261
G0 X143.261Y408.672
G1 X134.625
G1 X143.261
G0 X143.261Y405.624
G1 X134.625
G1 X143.261
G0 X143.261Y402.576
G1 X134.625
G1 X143.261
G0 X143.261Y399.528
G1 X134.625
G1 X143.261
G0 X143.261Y396.48
G1 X134.625
G1 X143.261
G0 X143.261Y393.432
G1 X134.625
G1 X143.261
G0 X143.261Y390.384
G1 X134.625
G1 X143.261
G0 X143.261Y387.336
G1 X134.625
G1 X143.261
G0 X143.261Y384.288
G1 X134.625
G1 X143.261
G0 X143.261Y381.24
G1 X134.625
G1 X143.261
G0 X143.261Y378.192
G1 X134.625
G1 X143.261
G0 X143.261Y375.144
G1 X134.625
G1 X143.261
G0 X143.261Y372.096
G1 X134.625
G1 X143.261
G0 X143.261Y369.048
G1 X134.625
G1 X143.261
G0 X143.261Y366
G1 X134.625
G1 X143.261
G0 X143.261Y362.952
G1 X134.625
G1 X143.261
G0 X143.261Y359.904
G1 X134.625
G1 X143.261
G0 X143.261Y356.856
G1 X134.625
G1 X143.261
G0 X143.261Y353.808
G1 X134.625
G1 X143.261
G0 X143.261Y350.76
G1 X134.625
G1 X143.261
G0 X136.053Y341.377
G1 X127.417
G1 X136.053
G0 X136.053Y338.329
G1 X127.417
G1 X136.053
G0 X136.053Y335.281
G1 X127.417
G1 X136.053
G0 X136.053Y332.233
G1 X127.417
G1 X136.053
G0 X136.053Y329.185
G1 X127.417
G1 X136.053
G0 X136.053Y326.137
G1 X127.417
G1 X136.053
G0 X136.053Y323.089
G1 X127.417
G1 X136.053
G0 X136.053Y320.041
G1 X127.417
G1 X136.053
G0 X136.053Y316.993
G1 X127.417
G1 X136.053
G0 X136.053Y313.945
G1 X127.417
G1 X136.053
G0 X136.053Y310.897
G1 X127.417
G1 X136.053
G0 X136.053Y307.849
G1 X127.417
G1 X136.053
G0 X136.053Y304.801
G1 X127.417
G1 X136.053
G0 X136.053Y301.753
G1 X127.417
G1 X136.053
G0 X136.053Y298.705
G1 X127.417
G1 X136.053
G0 X136.053Y295.657
G1 X127.417
G1 X136.053
G0 X136.053Y292.609
G1 X127.417
G1 X136.053
G0 X136.053Y289.561
G1 X127.417
G1 X136.053
G0 X136.053Y286.513
G1 X127.417
G1 X136.053
G0 X136.053Y283.465
G1 X127.417
G1 X136.053
G0 X136.053Y280.417
G1 X127.417
G1 X136.053
G0 X136.053Y277.369
G1 X127.417
G1 X136.053
G0 X136.053Y274.321
G1 X127.417
G1 X136.053
G0 X136.053Y271.273
G1 X127.417
G1 X136.053
G0 X136.053Y268.225
G1 X127.417
G1 X136.053
G0 X136.053Y265.177
G1 X127.417
G1 X136.053
G0 X136.053Y262.129
G1 X127.417
G1 X136.053
G0 X136.053Y259.081
G1 X127.417
G1 X136.053
G0 X136.053Y256.033
G1 X127.417
G1 X136.053
G0 X136.053Y252.985
G1 X127.417
G1 X136.053
G0 X136.053Y249.937
G1 X127.417
G1 X136.053
G0 X136.053Y246.889
G1 X127.417
G1 X136.053
G0 X136.053Y243.841
G1 X127.417
G1 X136.053
G0 X136.053Y240.793
G1 X127.417
G1 X136.053
G0 X136.053Y237.745
G1 X127.417
G1 X136.053
G0 X136.053Y234.697
G1 X127.417
G1 X136.053
G0 X136.053Y231.649
G1 X127.417
G1 X136.053
G0 X136.053Y228.601
G1 X127.417
G1 X136.053
G0 X136.053Y225.553
G1 X127.417
G1 X136.053
G0 X136.053Y222.505
G1 X127.417
G1 X136.053
G0 X136.053Y219.457
G1 X127.417
G1 X136.053
G0 X136.053Y216.409
G1 X127.417
G1 X136.053
G0 X136.053Y213.361
G1 X127.417
G1 X136.053
G0 X136.053Y210.313
G1 X127.417
G1 X136.053
G0 X136.053Y207.265
G1 X127.417
G1 X136.053
M8
G0 X143.559Y199.043
Layer C02
G1 X38.559
G1 Y345.043
G1 X143.559
G1 Y199.043
G0 X140.099Y348.633
G1 X35.099
G1 Y494.633
G1 X140.099
G1 Y348.633
G0 X143.46Y47.367
G1 X38.46
G1 Y193.367
G1 X143.46
G1 Y47.367
M9
G1 S0
M5
G90
G0 X0Y0
M2
Stream completed in 22:02
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
Starting stream
G00 G17 G40 G21 G54
G90
G0 X443.144Y676.5
G1 X798.856S0F6000
G1 Y823.5
G1 X443.144
G1 Y676.5
G90
Stream completed in 0:00
<Idle|MPos:443.150,676.500,0.000|FS:0,0|Ov:100,100,100>
ok
Starting stream
G00 G17 G40 G21 G54
G90
G1 X798.856Y676.5S0F6000
G1 Y823.5
G1 X443.144
G1 Y676.5
G90
<Idle|MPos:443.150,676.500,0.000|FS:0,0>
ok
Starting stream
G00 G17 G40 G21 G54
G90
G0 X473.144Y676.5
G1 X828.856S0F6000
G1 Y823.5
G1 X473.144
G1 Y676.5
G90
On the console window, uncheck the “show all” little toggle to the right side
Then in the box that says “type command here”
type $$
Press enter
Copy/paste the output after that command and send please.
Usually, belts on extended frames tend to lose track on the rapid movements.
In other words, from object to another object
The bigger the “Jump” the higher chances of lost steps or accuracy.
