You argue about English, I use Google Translate.
I have a doubt, when I make a raster of an image, if for example I apply 150mm / s the head moves out of the drawing about 10mm (Without dipping, it is like to brake smoothly) and if I increase the speed, for example to 300mm / s , the head moves to the sides about 30-40mm (For example), I understand that the higher the speed, the greater the braking distance, but this makes increasing speed, the engraving time also increases for this reason. Is it possible to change this setting so that the stopping distance is shorter? (RUIDA 6445G)
Currently I also use a Mini Gerbil controller on another machine and with this I do not have these problems.
