There was a similar post but it looks like contents deleted. New to LB and the Forum.
If project paused and layer setting changed will they be immediate or will I need to restart LB?
Once you start a job it is saved behind the scenes and run separate from the active design window. Pausing would not do anything. You would have to stop the job and restart it from scratch with the new settings. Or perhaps you can use the “start from here” functionality in the preview window to get close to where you left off. But you do not have to close the program window.
oh didn’t notice this feature… that is perfect! sometimes i start a cut and realize “oh i could have used more (or less) passes”. now i can stop, edit cut settings and move past what it has already cut… and “start from here” brilliant
Thank you I will give that a try tomorrow. Ball game today in our Shop.
