Ikier K1 fibre, the Y axis frames the subject, but fires 4mm under
I have tried everything I can think of, scoured the board, but REALLY need some help.
Homes to x0 Y470
When I start a run it instantly hits the out of range alarm now…this is a new problem!
Can anyone help me?
Please!!
Maybe @berainlb can give you a hand… it’s a fiber source, but on a grbl controlled gantry if I’m not mistaken…?
I’m not the grbl person that knows about these… I’m wondering why it comes up with such an odd origin…
Hang in there…
Can you provide the following:
  1. To what corner does the machine home?
  2. Full screenshot of LightBurn with your design loaded and ready to burn
  3. Run these commands in Console and return the full output:
$H
Homes front left
Screen shot for both
You didn’t type the 2nd and 3rd commands correctly. Can you try again?
Also, if you use “Absolute Coords” as your start from mode, does that make a difference?
Many thanks for this help.
Absolute cords, no difference.
Screen shot of (hopefully) the correct command!!
You got the second command correct there. However, you missed the last command, the ? command. Can you please run through the commands again as I want to validate position.
You have an work offset configured. Is this deliberate? It’s likely the cause of what you’re experiencing but can’t imagine it would ship like this from the factory without a reason.
However, would need the output of the full set of commands to confirm.
That is not deliberate!!
Will do that first thing and post here.
Thanks again, this is new to me, and the back end confuses me.
We have a very large confused boat group … when you are just learning about these we’ve all been in that boat…
Just sing out if you have issues.
Here you go.
It may not have shipped like that, big fat fingers may have fiddled…a bit!
That confirms it. Let’s remove the work offset. Run this in Console:
G10 L2 P1 X0Y0
Then home and retest and report back please.
Howdy, it instantly says exceeds maximum range of motion when asked to frame a job, after homing
Can you rerun these commands and return full output:
$H
Also, please include a full screenshot of LightBurn with Laser window in view.
Here you go.
A couple of things to look at:
  1. The name of your laser is “GRBL-LPC”. This is typically true if GRBL-LPC was auto-detected as the device type. However, your machine is likely meant to be configured as “GRBL”.
    Push Devices button in Laser window, edit the device, change to “GRBL” and also rename your device.
  2. Can you confirm if your jogging controls are working correctly? Left moves left, right move right, up moves up, and down moves down?
  3. The status message is indicating that the Z-axis limit switch is being actuated. Can you check the laser module to check if something is happening there?
  4. Once you’ve done all these, try rehoming and retesting. If it doesn’t work, take a screenshot showing the exactly message.
Wooo And indeed Hoo!!
It lives!
The last problem…always been there I think, frames perfectly, as soon as I press start, it completes the project, just 4mm lower than it should be
i might be mistaken but dont Ikier has a built in offset because of the Cross dot?
Are you following the Ikier lightburn profile creation instructions?
No, the fibre on has the annoying intersecting dots.
Would really like the cross.
Are the intersecting dots used for both focus and framing? If it’s also intended for framing, is there an offset between the intersecting dots and the primary laser? And if so, does that account for the 4 mm difference?
I will go and try that now!
