I'm sure this is covered somewhere but
I’ve used the Trace and Node Edit of Lightburn a number of times… somehow this morning (I’m in a hurry of course) I’m trying to get an image modified and after tracing, the resulting vector is not showing nodes when I select the “Edit Nodes” tool from the left, vertical tool bar. What am I missing?
My source image was a copy paste from something I found on the net - a silhouette so there the tracing should be easy. There are a couple internal vectors/cutouts in the image - they are tracing fine. I can’t ‘break apart’ the vector to remove or individually edit the internal cutouts.
I’m pretty sure I’m missing a simple basic step here… but not sure what it is?
Thanks in advance!!
Arden
usually the case is that you need to ungroup the image. it wont show nodes if its multiple objects that are not physically connected (even if they look like they should be connected)
I KNEW it would be something simple…sigh
Thanks for the quick response - I really appreciate it!
