"Избражение" не рисует ("Image" doesn't draw)
error:1
Пишет на консоли - error:1 Слова G-кода состоят из буквы и значения. Буква не найдена. На или около линии 0:
Writes on the console - error:1 G-code words consist of a letter and a value. Letter not found. At or near line 0:
Read the following doc and come back if you have more questions.
Incorrectly selecting iLaser when building the device profile can cause this.
Also, having G Code Clustering selected in the Device Settings window can cause this behavior with engravers that do not have G Code Clustering.
Edit - Device Settings - switch off Enable GCode Clustering - click OK at the bottom
Then retest.
