Image flipped in both direction
Hi @LightBurn_Staff , trying to give help to a user i downloaded his project from here
but when i open it on LB this is the situation i find
this can be easily explained with different size in bed working area but
the work is flipped in both direction, as you can see
The project was saved from a copy of LightBurn with different machine origin than yours is set with. Machine origin is saved in the project and used as a reference for how the design is loaded. Working as designed. You’ll just need to flip the design to match your machine origin.
Ok now i’ve understood
