I have downloaded an etsy svg file and center traced in inkscape and put back into LB
the trace rounded a square corner and I thought if I could place a node there I could maybe square it back up, but I cant do anything with the node functions they are greyed out Is there a way to add a node if the img has none
Vector files have nodes… Image files do not.
If you can, instead of an image, use the center trace and export it as a vector file … dxf or svg.
