Image not centering during engraving
I upgraded to software version 2.2.00. When I frame the image, it frames in the correct position. When I attempt to engrave, the image moves about 3/4 of an inch to the right. These images were framing and burning properly prior to me installing the RA1.
I was recently using the RA1 rotary tool, but I made sure the rotary tool is no longer enabled in the Laser Window tab. The RA1 has been disconnected from the system. I installed the xTool_D1ProV3.lbdev in order to get the rotary to function properly. I then reverted back to the xTool-D1.lbdev. The issue is still there. The image I’m using functioned properly before I installed the RA1 Rotary device.
I’m using:
Lightburn 2.2.00 with an xTool D1 (not Pro).
Windows 10 Home, version 22H2, OS Build 19045.6466
Lightburn 2.2.00
xTool D1 (not Pro)
Please let ne know if you need any further information.
Any suggestions you may have would be greatly appreciated.
Thank you!
Bill Hoehne
See if Laser Offset is turned on and what the settings are. Its under Edit > Device Settings If its on you should be framing with the Red X instead of the blue laser. If its off frame with the Blue Laser
If Laser Offset is on and you are framing with the Red X but the job is not cutting in the correct position then the X and Y offset is not correct and you will need to adjust the offset
Here’s an easy way to check or set Laser Offset
Turn off Laser Offset
Make a small box and engrave it on a piece of scrap
Turn on Laser Offset
Position your laser on the bottom left corner of the box you just engraved using the Red X
The box should burn exactly over the first one you did
If it doesnt adjust the X and Y settings in laser offset and repeat the procedure
To get an idea of where to start you can use a metric ruler and measure the offset between the Red X beam and the Blue Laser beam when both are projected on a piece of scrap
