Image printed mirrored
I have been using Lightburn free trail. As soon as I signed up for subscription and entered the activation all my images are lasering mirrored.
Maybe you can go to Device Settings and check the laser Origin:
Welcome.
From time to time, the laser engraves a mirror image on its own initiative
The best way to avoid surprises is always doing a Preview before Firing The Laser:
If the image is correct in the Preview and mirrored on the material, then upload:
Everything is working fine. Nothing be changed. You run one file and it mirrors it; the next one is fine, without changes. It happens on the fly and is at the discretion of the laser/driver/something else? I need to know what to check or what to do—reinstall, run some kind of debug, try an older version… I’m not the one operating the laser; I just receive and relay information.
The first step is to determine exactly where the reversal is taking place:
  • The design
  • The commands sent to the laser
  • The controller on the laser
Which is what the Preview will tell us, which is why that’s the first thing to check.
If you can come up with a situation where the Preview is correct and the output is reversed, providing the information I asked for will let us proceed.
Then you must get the operator(s) to do the checking, because we don’t know enough to recommend anything further.
If the workflow involves two different PCs, one for design and another running the laser, then we need the configuration on both PCs.
