When I am doing multiple objects on the same run the “fill” part begins to shift to the right. It starts out ok for the first row but then the fill portion shifts. I exported the same file to RD Works and it works fine so something in LB is causing it. Attached is a pic of what I am talking about. I shared this with a friend who has been doing this for 10 years, uses LB, and he has no clue. Any help would be appreciated
When you ran it in RDWorks did you use exactly the same settings for everything? Did it run the path in exactly the same order? Do you have the Small Circle Engraving speed limits set in RDWorks?
The machine is skipping when running the text (ie, your steppers are losing steps) which is caused by running the cuts too fast or having the Idle Accel setting in the machine too high (and/or possibly the Idle Speed).
