Image size cut in half on y axis
Hello, I hope I’m putting this in the correct place. I’m currently using a FoxAlien Masuter Pro. Recently when I go to laze a design, the x axis lazes the correct amount, but the y axis does not. For example, I drew a 6x6 box in Lightburn. It lazed the box 6"x2.75". I was using the rotary setting but I have since turned it off (laser tools > rotary settings > disable rotary)
Here are my machine settings showing I’m reporting inches
Here are my settings
Here are the $$ settings
Any and all help is greatly appreciated!!
Make sure rotary is disabled. Turn your machine off. Close and restart Lightburn. Restart your machine. Verify rotary is still disabled. Type $$ in console and verify that $100 & $101 both = 80. If 101 doesn’t =80 type $101=80 and enter.
