I am trying to engrave an image with text included and on the screen the text is correct, after the laser finishes the text is reversed. I looked on here and saw about matching the origins so I did that, now on the screen the text is reversed so I figured the finished product would be correct but it’s still coming out reversed. Any ideas? Is there a setting I’m missing?
Now that you have the origin set correctly, you need to just use the flip Horizontal command on any drawing that was done BEFORE you had the origin selected correctly. All new drawings will be correct.
Select All (Ctrl-A) then flip horizontal (H) and re-save.
