New at this, I can laser deer, animals, trees and do signs, ect. But when I do an image the laser runs continuous, no image just solid black. I have done images before with some success not perfect but now no success. What am I doing wrong? Thanks
Provide a few things please:
- Verify that your device is setup as GRBL (not GRBL-M3 or other) by clicking Devices in Laser window. It will list your device type and name.
- Check that $32 is set to 1 in Edit->Machine Settings
- Upload a .lbrn file that exhibits the problem you’re facing
Device is correct, machine settings $32 is true. Start an image, frame and start and laser stays on, no change in power, ??? Thanks
I have a laptop in shop and in the house, same thing with both laptops. Thanks
Can you upload a .lbrn file with an image that exhibits this behavior? Likely a setting issue but hard to say.
Can you upload the actual project file? I’d like to see the settings that you’re using.
