Can someone assist me with this please. I have imported two images which have been traced to line+fill, a baseball on top of two bats. Is there a way in lightburn that I can hide or cover up the bottom image where both images overlap?
What I’m trying to do from the image is hide the bat behind the ball, so there are crossed bats with a ball in the middle.
I think you’re looking for the ‘mask’ option. Here are the Lightburn docs on it, but you can search the forum for many discussions. There’s also a lot of tutorial videos.
Having a short read of the few threads provided in this post might assist with understanding. A bit hard to identify the exact shape or layer causing this, from the image you share. You can post the file if you’d like more direct feedback.
I have these two images that I have traced and welded as per above instructions by RalphU. When I put the ball into the circle, The circle turns black.
I need both lays to be set on Fill+line. I do understand why it is black…due to the layer set as Line+fill. I was trying to find a way for the ball to show up. I can put the whole thing on 1 layer as long as it’s line+fill, sorry for the confusion. I was playing with a faster way to burn with adding layers.
I’ll be darn it worked. I’ll read the FAQ How do I invert a vector engraving? closer cause I don’t understand it…but I need too. Thank you all very much and Ralph I see where you mentioned to add the additional circle but I think I had it inside the ball. Again thank you all!
Yes, add another circle or take one away to get the correct fill sequence. When reviewing the FAQ, consider the shape boundary to be a switch for filling.
