Images turn into a black mess
Hi everyone.
I feel like I’ve tried everything and watched several YouTube videos, but I can’t get this image to turn into anything other than a black mess. Could someone point me in the right direction? I’m afraid I might have become too close to the problem to see it clearly.
I’ve tried tracing it and adjusting it. I’ve also tried various picture settings—all without success.
The laser I use is a NEJE 80W.
I use LightBurn version 2.1.0.4
The material is 3 mm plywood.
The image must be 25x25 mm in size.
Might want to post what your results are.
Either you doing color somehow, but we need to see what you’re ending up with along with the cut/layer settings.
:grinning_cat:
I plan to try this tomorrow, but I’m honestly at a loss as to what to do.
It’s a really low contrast bird, so goose the gamma really hard:
Done on black test paper (with Negative image On):
Random plywood at 400 mm/s and 40 / 20 / 15 % with a 60 W CO₂:
I suspect fiddling with the image adjustment settings will get you most of the way there, then more speed / less power for the win.
Thank you very much for that. I will try that. Is there a way I can remove the black background in the picture?
Assuming you want to keep it as a raster image, then the best way is using an image-processing program.
For example, in GIMP (doc):
  • Select by Color to get the background and a few other bits in the eyes & beak
  • Toggle Quick Mask On
  • Scribble over the bits with a wide black Pencil
  • Toggle Quick Mask Off
  • Use Bucket Fill to dump white into the selection
Which looks like this:
Then proceed as before.
You could tinker with the contrast & suchlike in GIMP, but LightBurn seems good enough.
