Implement 'H' for Hand Tool Navigation
When will you finally implement the ability to press the ‘H’ key to activate the hand tool for screen navigation—just like in other DTP software? It’s frustrating to always have to manually select this feature with the mouse.
Many thansk :slight_smile:
Hi Sig
not H but if you are in the grid and press and hold SPACE bar you get a “Hand” that allows you to pan the screen around.
You can also pan around with the “Hand” if you press and hold the mouse wheel…
Can also be used outside the Grid area…
True that too! thank you Merlin
  1. It works outside the grid too.
  2. I just discovered this is easier to use than the thumbwheel!
