Import DXF Files / Kicad for PCB engraving with laser fiber
Hi,
I order my first laser fiber engraver and im new user with lightburn. I try to import my pcb that i do with Kicad. I export in DXF files but i have some prbs with the orign. The draw are not on the right place. Have solution to import on the right place ?
Regards
Kicad does not, in general, produce usable DXF files without careful attention to detail. You may get better results with SVG files, again with careful adjustments.
These previous discussions will be helpful:
There’s plenty more to read.
You say you have a hobby laser, is this a fiber? What kind of wattage? MOPA?
I had little issues getting a pc layout to Lightburn, just had some very stinky problems with FR4 material and the laser. Lots of people do it on a fiber, I’m just not comfortable doing that.
There are lots of examples on youtube. Here’s a video with a different slant on it.
Many of us here would like to see your results…
:grinning_cat:
Thanks for your reply
I bought a laser fiber 30w not Mopa. I don’t have it yet ! I don’t know why when i import my dxf i loose the origin in lightburn
Open your Settings window, Import/Export tab. So a screen capture (CTRL+WinKey+S) and put it in a Reply. This may help explain why you are getting unexpected results.
Fiber machines generally have an origin as front/left. You can’t modify it anyway, so what are you doing that this is an issue? If we understand the problem, maybe we can be of more help.
:grinning_cat:
@ednisley
I try to show you i read your post and try to export in SVG and import in lightburn.
I put my kicad files and svg and lightburn project in zip files http://kmeg.free.fr/LDS02RR-PIN.zip
Regards
If none of the workarounds in those discussions help, then the least-awful way to use a Kicad layout may be to create a high-resolution PNG image of the layout, import it into LightBurn, then trace it to get the outlines.
Part of the problem comes from the way Kicad produces the output files:
@ednisley thanks for your reply ! i think i fin solutions can export in DXF but need to export in one files. I don’t put the holes yet but i have this i think is good now.
regards
To engrave place a Rubber Band around the shape then group as in the bottom pic.
You have open shapes. Three lines can’t meet or the machine doesn’t know what path to follow.
I circled a few you’re going to have to fix with the node editor.
:grinning_cat:
