Import Units of Measure
I’m new to LightBurn and have been using RDWorks up to now. Is there any way to make LightBurn import mm DXF files correctly? So far, I have found that I need to save my drawings in meters which LightBurn then imports as mm. Now, I have two different lasers and they read the DXF files differently which means I’ll need to duplicate all my drawings, one set in mm and the other in meters.
I always import my DXF files directly into Lightburn in mm. I make them in Autocad which is in mm, then just save as DXF and import, never had a problem.
Might be a setting in Lightburn you need to set primary units to mm maybe…not sure. But yes it’s possible
Solution - disable “auto detect units if possible”.
