Importing *.mage file
Even though the import files list .mage file as able to be imported I can’t get the .mage file to import into Lightburn as I want to run the mage file through the laser in Lightburn
Save as .jpeg or .png then import to LB.
Doing that doesn’t allow me to add laser outlines & shading to my MillMage carving after I have CNC’d the 3d item. I could do it in Carveco which adds shading to my 3d carve. If I use *.png will that provide what I am asking of the 3d item
There is no way to save as a jpeg or png in millmage
Does that link help. Sorry didn’t know you were dealing with MM.
I just tried as an SVG but no luck, I will give the DXF a try. Lightburn gives the option to open .MAGE files but doesn’t appear to work
I found that link in topics search “Millmage files”. There were quite a few topics listed so a look through might uncover what you need.
CTRL-C in MillMage and CTRL-V in Lightburn. I do it all the time.
You may have to make adjustments in the Cuts Editor window, but you would have to anyway.
Edit: It works both ways.
Second Edit: You are copying the design space. Nothing related to the control and output applies. One is CNC Laser, the other is CNC Mill.
I tried the copy and paste but doesn’t bring in the 3d job from MM
Because Lightburn is not 3D. You would have to flatten the 3D first, then copy it.
What I am trying to do is bring the finished 3d job to Laser the different shadings of the depth map. So I thought seeing the open file lists *.MAGE as an available file option would allow me to setup this job in Lightburn
How do I flatten the 3d?
Never had to do it, so at this time I have no idea. Can you upload your STL file. I also need to know what your expectations are. The 3D viewed looks like a ghost, so it will have poorly defined lines and no detail.
Did it start out as a 3D image, or was it originally a flat image that got converted by A.I.?
Thanks for getting back to me Mike, yes the file is an original 3d STL file and is a depth map. My expectation was to bring in the MM file to LB so I retain the exact size and origin to work with the laser to outline and burn shading on the finished 3d timber carving. But I might be expecting to much by the look of it. This forum doesn’t give me the option of uploading an STL file by the choices that are available in the upload selection.
The file in MAGE is too big so I will have to share the link to it once uploaded.
But appreciate your help Thanks
Bear Snowboard 160x160.mage
11941 Snowsurfer Bear.stl
Carey, what version of LightBurn are you using? 3D support is very new, and we’d recommend using the 2.2RC
2.1.04 Colin
Try 2.2 here: Index of /LightBurn/RC/LightBurn-v2.2.00-RC-2/
Will this pre version allow me to import the .mage file from MM?
