In spiegelbeeld
All assignments work fine on the laptop. texts are mirrored on the workpiece when I want to laser cut or print on plywood. I use Sculpfun 10
You most likely set the origin incorrectly. Check this guide how to set up LB properly: Setting up the software – Diode Laser Wiki
