Buongiorno, sto avendo dei problemi con l’incisione interna anelli !
In pratica nell’incisione interna le lettere vengono attaccate l’una all’altra e non riesco a capire come dare spazio tra le lettere. Cosa che non si verifica con l’incisione esterna.
La mia macchina è una GALVO 20W JPT M7 MOPA
Good morning, I’m having problems with the internal engraving of the rings!
Basically in the internal engraving the letters are stuck to each other and I can’t figure out how to give space between the letters. Which doesn’t happen with the external incision.
My machine is a GALVO 20W JPT M7 MOPA
Simplest guess is you don’t have your diameter set correct, need to accurately measure your inside diameter. I do rings occasionally only issue is I forget to reverse rotary direction sometimes. Assuming you are using a chuck rotary.
The HSpace field in the Text Options toolbar controls the between-character spacing: positive numbers increase the spacing, negative numbers decrease it.
