Inconsistency in LB
I am using version 1.7.03 of LB.
I have encountered what seems to be an inconsistency in the software.
In the Move panel, if I use a dot as the decimal separator, the program does not recognize it and interprets 0.64 as 64, which usually triggers an Alarm.
On the other hand, in the Settings and Cuts Editor of the Cuts and Layers panel, the opposite happens: it only accepts the dot as the separator.
Does this happen to everyone, or is it an issue specific to my installation?
Let me know if you’d like any adjustments!
Try changing your Windows region format to US and LightBurn to English. Check if this works.
