# Incorrect factor for feed rate difference between linear and rotation axis
**URL:** <https://forum.lightburnsoftware.com/t/incorrect-factor-for-feed-rate-difference-between-linear-and-rotation-axis/142648>\
**Tags:** grbl, rotary\
**Created:** [June 27, 2024, 10:45am UTC](https://forum.lightburnsoftware.com/t/incorrect-factor-for-feed-rate-difference-between-linear-and-rotation-axis/142648 "2024-06-27T10:45:48Z")\
**Showing post:** 2
**Author:** ![parsec](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/parsec/32/118933_2.png) [@parsec](https://forum.lightburnsoftware.com/u/parsec)\
**Post date:** [June 28, 2024, 3:10pm UTC](https://forum.lightburnsoftware.com/t/incorrect-factor-for-feed-rate-difference-between-linear-and-rotation-axis/142648/2 "2024-06-28T15:10:41Z")
Check this thread.
> [@Lightburn + Snapmaker Guides](https://forum.lightburnsoftware.com/t/lightburn-snapmaker-guides/96176):
> For those that dwell here instead of the snapmaker forum, I figured I’d drop by and help out. slight_smile I’ve done several guides making Lightburn my full control software for the Snapmaker wirelessly, and it even helped me figure out how to use the Wifi on my new XTool D1 Pro with Lightburn (still have to poke the button on the machine to start it, but no tethering needed!) Instead of copying the entirety of all the guides, I’ll post the links here so users can scroll through the posts to …
_[View the full topic](https://forum.lightburnsoftware.com/t/incorrect-factor-for-feed-rate-difference-between-linear-and-rotation-axis/142648)._
