Hi I currently have a Neje Master 2 20 W 6x6 engraving area. I am planning to enlarge the area to 19 x 25 After the driver and head are moved and plugged in please let me know if this is the correct procedure
I go to lightburn
2} add device.
3} choose grble
put in dimensions.
Unless there is a way to pick the neje and change the size?
If you already have your device configured in LightBurn, you can edit the existing config. Click the Devices button, select your controller from and click the Edit button. This will go back through the setup of that device and you can change the necessary parts.
