Increase spead of gantry travel
Since I am not able to decrease the power of the laser I would like to increase the speed of the X and Y axis travel.
I have checked the $110= and the $111+ settings and both are set at 18000mm/m.
Acceleration Settings, $120= and $121= are both at 1000.
I have adjusted the speed in the Engrave file but does not make any differance above 3000mm/m.
How can I increase speed highter? What am I missing?
What laser are you using? You can’t just increase the speed via settings, your mechanics need to follow. You can enter light speed into the fields, but the mass needs to be accelerated, and with most lasers, 3000-6000 mm/min is the realistic maximum mechanically.
Assuming the machine looks like those, then it has leadscrew-drive axes intended for CNC machining, rather than laser engraving. The maximum speeds listed for those machines are around 5000 mm/min, which isn’t much above the 3000 mm/min you observed.
Assuming the leadscrews have the same 4 mm lead as the ones on my much-modified 3018 CNC, then each motor revolution drives the axis 4 mm, which means the motor turns at:
1250 rev/min = (5000 mm/min) / (4 mm/rev)
Which is about the maximum RPM a NEMA 17 can handle before the torque drops to nothing and the motor stalls.
Without knowing the details of the Rothman controller, it’s reasonable to assume 8:1 microstepping, so the maximum pulse rate from the controller at that speed is:
33,000 step/s = (1250 rev/min) Ă— (8 Ă— 200 step/rev) Ă— (1 min / 60 s)
Old-school Arduino controllers had an upper step limit around 40 kHz, but I assume STM32 controllers can go higher. The upper limit may be set by the hardware, with the compiled-in firmware capped at that pace.
Any and all of those assumptions will be wrong, but the bottom line, however, is that the machine cannot go much faster than about 5000 mm/min, because that’s the physical limitation imposed by the design.
Which is why machines designed for laser engraving have belt drives: each motor revolution moves the axis about ten times farther than a leadscrew.
Sorry I did not mention, This is my CO2 machine with gates belt drives. Not sure of exact brand but it is China made. This is the same machine that has the Monport control board. Not the Tim Rothman control board
Roughly 420mmx460mm size. Even at 1000 for the acceleration ($120= and $121=) it has never stalled. This is part of the reason I thought it should have more speed. What else regulates the speed other than $110, $111 and $120 and $121 ?
Now we all know.
FWIW, you can update the machines in your forum profile using the link hidden at the bottom of the License Management dropdown in the upper right.
That is entirely up to Monport or whoever wrote the controller firmware, but there may be an undocumented setting capping the overall speed. Ruida controllers, for example, have several undocumented Cut and Engraving parameters that (apparently) limit the values in the axis sections:
If you can’t find any doc for the specific firmware version in the controller (which is, regrettably, typically the case) and spelunking the Machine Settings doesn’t reveal anything relevant, then you’re pretty much stuck.
Note that the acceleration values don’t affect the speed, just the distance required to reach that speed. You can feed the speed & acceleration values into a calculator to estimate the distance:
You may need to convert the speed & acceleration values to the correct units. Reaching 18000 mm/min = 300 mm/s with 1000 mm/s² acceleration requires a little under 50 mm, so you can try boosting the acceleration to 3000 mm/s to reduce the distance and see what happens.
However, 300 mm/s may be about as fast as the machine should go with the laser tube active. The tube response time is about 1 ms, which means a single image pixel will be 0.3 mm long at 300 mm/s. Engraving an image at more than 85 DPI won’t do what you expect because the laser can’t resolve smaller pixels.
confused more than ever now. I have other issues I would like to correct but having difficulties.
It’s best to start a new topic for each of those, as glomming everything into one huge thread makes it difficult to figure things out.
Please update the machines in your profile, as I suggested earlier, and describe which machine you’re using in each new post, so we can avoid starting with a whole pile of incorrect assumptions.
