Initial Flash When Starting Laser Module
First off thank yo for allowing me on the forum.
I am unsure of the correct terminology but, when my laser (NEJE 40640 w/ air assist) turns on to start an engraving or cut there is a small amount flash burn on the work surface upon the turning on/off of the laser module.
Is there a way to stop or diminish the flash burn (in the Lightburn software) area when the laser is initially turned on ?
Thank You
Tom
Please share a picture of what you’re seeing.
If it’s a filled image it can be a matter of excessive speed or insufficient overscan.
If it’s a line or path behaviour then I hope someone here will be more familiar with the motion planning in Marlin than I am.
