When I launch Lightburn, or reset windows to default, I don’t see the colour bars at the bottom. If I maximise the window it will appear but disappear again if I change something else. It only seems to do it on the laptop I use for driving the laser, not the desktop I use for designing.
Also what controls what you see in the console window? Sometimes I see G code, other times the name of the layer being cut and the pass number.
I’m baffled.
What’s the vertical resolution of your display? If it’s less than 838 pixels then it’s possible that there’s not enough real estate to fit the layer palette with the default layout.
Check out this video on how to resolve:
If that’s not the problem, can you take a full screenshot of LightBurn showing what you’re seeing?
