Install start switch
is it possibel to install start switch like the home switch to start the laser instead use the screen on the program because i made load and unload matérial
I think I know what you’re after. Please forgive me if I misunderstand your goal.
You can define certain locations in the Move window.
Click on Manage, then Add New, then click OK
Here I’ve created one called 'Load Material"
In your Move window it will show as a saved location.
From there simply click on Go and your laser will move to those coordinates saved earlier.
your thing is good but i need the switch to start the laser because when my robot unloads and reloads the robot should be able to start the laser thank you
Could you get a programmable keypad and assign a shortcut to start the laser?
Yes i find i use arduino to send f5
